Performax 16/32 Parts?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=23273
Author:  Brock Poling [ Fri Jul 31, 2009 1:29 pm ]
Post subject:  Performax 16/32 Parts?
Does anyone know where I can get parts for a performax 16/32? The motor mount which holds the vertical adjustment screw bit the dust. All the threads that the screw uses to lift the housing wore off.
Author:  Steve Saville [ Fri Jul 31, 2009 1:37 pm ]
Post subject:  Re: Performax 16/32 Parts?
Brock,
It should be a lot cheaper to repair it.
Do you know about Helicoil?
http://www.helicoil.com.sg/HeliCoil-Ins ... ctions.htm
Author:  StevenWheeler [ Fri Jul 31, 2009 3:32 pm ]
I was going to suggest the same thing as Steve. The nice part about the Helicoil is that you'll have steel threads for the lift screw instead of cast aluminum.
Author:  wbergman [ Fri Jul 31, 2009 3:52 pm ]
Are you aware that JET is the same now?
Author:  KeithM [ Fri Jul 31, 2009 5:33 pm ]
http://www.wmhtoolgroup.com/Parts.aspx
Author:  Bill Hodge [ Fri Jul 31, 2009 5:42 pm ]
Brock,
Looks like Keith beat me to the punch :) The Heli-Coil option is the cheapest though and will outlast the new cast-metal part you would buy to replace the worn one.
Author:  Brock Poling [ Fri Jul 31, 2009 6:21 pm ]
Steve Saville wrote:
Brock,
EXCELLENT! Thanks guys!
Author:  BruceHerrmann [ Sat Aug 01, 2009 7:20 pm ]
Repairing the thread should work well. I've switched from helicoil to Time Sert as a thread repair
system. Have used it most on auto repairs but it's a great system for any thread repair. Heli-coil
will hold up well in most situations but in high stress areas such as cylinder heads etc, Time Sert
is the way to go. http://www.timesert.com/
I've had good experiences with getting Performax parts from the factory, they have been prompt
and have the parts in stock. The feed motor on my belt drive system lost a gear, I had one in two days
with no charges. Not bad....
Bruce
